Ric
- May 7, 2010
- 5,765
looks like a solid unit. anything stihl is good. that would be a good blower for me to get, it looks like it would be a great all around blower, since i do leaves in the fall.
I think it will be a good solid unit. I used it a couple of times yesterday and it cleaned the sidewalks and there edges real well also did a real good job on the driveway and Home Entrance. I can tell you on a cold start if you set the Choke Knob it starts first pull and after you use the machine it warm starts on the first pull. If that last or not will see :smile:
One of the things I like about the unit is its 36oz fuel tank capacity, so run time on a tank should last me a day or more. The other thing would be That the BR-200 is not the Stihl 4mix unit, it's the 2 stroke engine so it has a 70db sound rating which the is a great deal different than the 60 to 63 db with there 4mix units.
