NeverGiveUp,
Well, I goterdun!!! Ended up costing me a total of $36.72 plus tax and some misc materials for wire routing & securing(nylon wire clamps & screws and nylon cable ties). I'll post pictures of the light kit and rocker switch below and here are the details of the materials, including the installation materials:
1)Blazer "Baja Tough" Driving Light Kit(55watt Halogen) Part#DF1088B-$19.99 which includes the necessary wiring and hardware for installation.
2)AutoCraft 30amp Rocker Switch(Red LED) Part#84840-$8.49
Both of the above purchased at Advance Auto Parts
3)Scotch(3M) Outdoor Mounting Tape(Two-sided adhesive tape holds up to 5lbs)-$4.27
4)Liquid Nails Adhesive(Home Projects For Extreme Temperature And Conditions) Part#LN-201-$3.97
Both of the above purchased at WalMart. The light kit came with mounting screws, but the best place to mount these lights was on the front of the gas tanks on each side just above the rear tires. Even though the plastic gas tanks are pretty thick I didn't want to take any chances. I cut the Scotch Adhesive tape to fit the inside of the light bracket(two pieces and two layers) and applied a small amount of the Liquid Nails on the light bracket, mounted the first two tape pieces to the bracket, applied a small amount of the Liquid Nail to that and applied the second set of pieces to the first pieces. Then I applied a small amount of Liquid Nail to the second layer of tape and pressed/mounted to the mower. I know this may sound a little strange....but it looks GREAT and it would take a crowbar to get those lights off my Gravely!!!!! I will post pics below of the light kit & rocker switch(drilled a hole in the plate where alll of the controls are at for the mower and it mounted easily).
Once I have a chance, I will take some pictures of the Gravely with the lights mounted and post them. I think you'll agree it looks like a professional installation!!
