Paul’s Toro
The speed of the idol is not the issue as the idle speed is very high. The issue is it randomly sputters and almost like a valve has a problem. I’ve tried tech Ron in it along with Marvel mystery oil. It recycles the grass in incredibly small pieces and runs beautifully except for the sputter. It also has a noise that sounds like marbles so mechanically it might even have a small rod knock. At this stage of the game I’ll just keep fresh oil in it and run it until it dies. Thank you everyone for all your assistance. I really appreciate it.m 20055 has one speed. You cant idle it. It is either on or off. When one lets the kill handle go the mower dies as designed. I would think the 20056 would do the same. If the rpm won't come up then something may be goofy with the governor circuit as others have suggested.
