Carl in CT
Wow, that's some serious discounts you are looking at. I think that would definitely turn my head their way to at least go check one out in person.
I took a quick look at their website and the ZT offers either the Kohler Courage or the Briggs Pro motor. The Kohler Courage is not even on par with the Command which is not good so I would run fast from that option. The Briggs Pro might be great, might not be great, I just don't know much about them. Now, the ZT Commercial is a $1,000 more but they offer it with the Briggs Vanguard on all 3 deck choices. That is a true commercial motor on what appears to be a commercial build ZTR with bigger tires, heavier duty hydo tranny, etc. If you can get at least $750 discount and you like the Bad Boy I'd definitely pony up the extra to get the Commercial ZT with the Vanguard motor and whichever deck you want. Is the dealer near you and seem like a good outfit that will work with you if you ever need anything after the purchase?
BTW, did you ever get a chance to test drive that Simplicity on some bumpy ground and see if the suspension is worth anything?
