Ric
Well my mind is set. I am going to get the 770T. I think it will be worth it. And I am going to get the tube-mounted throttle so that way if I really want to blow some leaves I can have my handheld blower in my left hand, and the backpack blower tube in the right hand (I wouldn't really do that-haha). I am going to get it at the end of August so I can have all of September to "break it in" and get used to the controls before the leaf season begins in October. Can't wait.
The 770 is a good blower, the problem I have with it is it's weight being just over 24 lbs and the noise it makes and I'm not talking about db, I'm talking about the sound itself. The 770 and for that matter most all the two strokes unless or except some of the smaller units are just nasty sounding. Personally if I'm a client I'd prefer listening to the the four stroke units over a two.
The thing your not considering is the sound. You use the db scale to compare sound and that's fine if your comparing the same type units. 73 db is 73 db. but that 73 db sound you get from your hand held that has a 25cc engine isn't going to any where close to a 75db from a back pack that's running a 64 cc size engine. I ran a BR 380 back pack for years and it was a great blower but being a two stroke, like the two strokes it earned it's name of screamer for a reason. That 770 is going to be twice as loud as your HH.
In comparing the BR 380 to the BR 600 that I use now I can tell you that you that the four stroke 600 isn't half as loud as the 380.
