Lowballers
I forgot you had one of those. What is so special about it to do that kind of work if you don't mind me asking.
The grounds master is a Industrial mower.
It is built for heavy duty abuse. Mostly used on a golf course.
It is not going to give you the best cut as it is not a finish mower.
Mine is a 1992 model I use it to clear under brush.
Has a 3cyl kubota engine.
The rear wheel steering is perfect for very steep hills.
You just can not break this thing. The 72 inch deck weighs close to 200 pounds.
It's like taking a pull behind bush hog and mounting on the front of a tractor.
What model do you have? I used 345, 327 gassers and 328 diesels for years.
One I was looked at was 11 foot Bat wing.
I really do not have a need for something this big.
Thought about putting a bid on 2 welcome centers on interstate 75
Unless you have a lot of open acreage it's way over kill. We use bat wing on some of our really large open facilities. I mow about 100 acres a week using 72"
Lowballers are coming out of the wood work. there advertising on craigslist with $10 and $12 cuts to include grass cut, trimmed, edged and blown off. Gonna be a wicked year.
How can they make any money at $10 bucks including trim and blow? Seriously? With gasoline back pushing $4 per gallon - exactly what is a person's time worth? WOW!
LOLOLOL I use to have one of those "fuel efficient Nissan Titans".... That is an oxymoron if I ever heard one! I liked that truck a lot, but man did it have an appetite for gas!
... I average 18 pulling a trailer 20 not...
