Ric has the key to this problem. In copying torque charts for the forum (threads, lube, torques-current) I note that a 1-1/8" nut in grade 5 takes 794 ft lbs to tighten. BREAKING TORQUE IS BEYOND THE CAPABILITY OF THE BEST RED NECK BREAKER BAR UNLESS IT IS A 10ft 4x4? This is heavy equipment tool capability? Again...why would a mfg set up such an obstacle to the poor home
gardener?:confused2: rfi also saw this clearly.
ERROR ERROR SORRY SORRY Entered the bolt chart ID instead of the backing into the shaft from the nut size discussed. If the shaft is 7/8 od the grade 5 torque is only 382 ft lb, but breakings torque is ? 420 ft lbs? If that bolt is put on dry it is beyond the capability of most home mechanics tools. So sandburs approach is understandable: neverseize drops required torque 45%, to 210 ft lbs, within the range of my trusty crafsman wrench. And breaking torque down to ?230 ft lbs, still a one man job. Ah, the joy of proper lubricant, Again my apology for the error. :ashamed:
