Ric
- May 7, 2010
- 142
- 5,765
:smile: What size of impact are you using and how much air pressure? I have removed plenty of blades off cadet decks and various other decks that have not been off in years. I spray them with PB blaster let them soak for awhile and then use my 1/2" inpact at 130 psi. Never had one that did not come off. Try this trick, heat the nut and when glowing red, take a candle and soak the wax in between the nut and the threads. Then put the inpact to it. Don B.
I don't know if your asking me or him about the impact, but I use an Ingersoll Rand 1/2" at 90psi Heck my air tank is a 6 gallon 2hp 150lb max Bosititch and it works great.
