So you said you used a torch. what i would do is get some penetrating pb blaster, and soak them in that and let it sit for an hour or so. then try it again, if that doesnt work then i would say find some way to cut the bolts off.
I used the torch to the point that the bearing grease started to boil and smoke, so I backed off. I have broken through welds with less effort than I have been applying to this thing and not a single nut will turn. I put the impact on it for over 5 minutes without it budging.
I am not familiar with your set up, but...does the deck come off? if so remove it and turn the nut upside so penetrating oil can soak overnight without running off. If the deck is upright can you partially hack saw one flat without damaging shaft threads, then strike hacksaw cut with cold chisel?
I know how tough this one must be, but if you have heated up the whole assembly you missed the advantage of heating only the nut so it expands away from the bolt. :thumbsup:
Sounds like you'd be ok with replacing the ?spindles? Can the spindle/blade/nut be driven out from the top with deletion of e.g. rivets? Put another way just save the deck? Also the cold chisel idea was to just break thru the nut flat to the threads so to "peel" away the nut from the threaded shaft.The deck is off and upside down. I did only heat the nut whereas the purpose of heating is for expansion and you want the nut to expand off the bolt threads....thus only what the bolt is going through is ever heated when using a torch. Penetrating oil has soaked all day, they are right hand nuts, and I don't want to have to replace the expensive assemblies because old blades are stuck to mine. I would consider replacing the shafts if I could get those off. A cold chisel would have about the same effect as the impact I am using as well as the rotary hammer I put on it. I have a garage full of tools and nothing is working. I just can't believe all three nuts won't turn. I talked to my buddy who owns a lawn service and uses cubs and he had no advice other than what I've tried. I may find a way to strap the deck down and attach an aerial winch to the breaker bar to see if 10,000 pounds of force will do anything (That's what we hoist the alligators up with)
There is one more catch....blocking the blades with a 2x4 does no good whereas the center hole of the blades are round (not star). Therefore they just spin when torque is applied to the nut. It's rather difficult to get a wrench on one side and put everything I have into trying to get the other side off.
I just bought a set of blades for my Cub Cadet Z-Force 44" and have run into problems removing the old blades. The three blades are each bolted on by a 1-1/8 nut. I have attempted to remove them with an impact wrench, socket and pry par, socket - pry bar - sludge hammer combo, torch, solvents, and praying. I cannot get a single nut to rotate and looking at the threads as well as the manual, they are common threaded nuts which left turning "should" loosen. Any suggestions? It's hard to even get a bite to wedge the blades stationery on this thing.
THANKS!
After you get them off, clean the threads good before reinstalling. In my opinion, I would never use anti-sieze on blade nuts or bolts. I always clean and dry torque.
I know where you are coming from, the problem is the nuts on the Z Force is that they are torqued at something like 110 to 120 lbs. I had a time with getting them off mine the first time. If it's the lap bar model you will also need a wrench to fit the middle spindle on top to hold that nut, if you don't you'll turn the spindle out from the bottom. Where in Florida are you located. They do turn to the left to remove the nuts and it will take a fairly good impact to remove them. You may want to consider taking the mower to the shop and let them remove the blades the first time or this time if someone got carried away installing them, just don't let them install them. When you get the blades off and you're ready to re-install them torque them at 80 to 90 lbs that's all you need.
metz12 said:Why wouldnt you use never seize on the blades if you dont mind me asking? will it loosen easier?
I don't think so. I just had this problem on a machine that I changed blades on mid summer and applied never seize. Tried to change them a few weeks later and couldn't get one bolt off. I solved it with a 300 lb co-worker pulling on the end of a 8' pipe on a 1/2" breaker bar. This was the Jacobsen in my avatar.
Most blade bolts or nuts are used in combination with a spring type locking washer, along with a split ring lock washer. This puts pressure on the threads when they are torqued properly. This dry torque is used to offset set the torque on the blade when they stop. You must realize the spinning torque of the blade is extremely high. If the threads are wet, over time the twisting force of the stopping blade can loosen the nut or bolt, creating a dangerous situation. Anti-seize is used on nuts and bolts that don't have twisting forces on them that could cause them to come loose on their own.
You must also realize that there are many different types of anti-seize materials. A few you might find are; copper/graphite base, nickel/graphite base, zinc, Moly, and Teflon. Each has a specific use, even though many many can be use in a variety of situations, but should never be used on certain jobs. Example, teflon's primary use is in areas where water is in the area, but should never be used at temps over 212 degrees, such as steam, unless it contains a high temp additive.
This is the short, sweet version and there are exceptions. Hope this helps.
Haul it to someplace that has a high torque impact gun. You will never break them loose without it. I had the same problem on my Bad Boy. There is no stop on the blade to keep them from getting tighter and tighter as they rotate. I tried to use my impact on them with no luck. I took the mower to the shop I purchased it from and they put their impact on it and spun them right off. Before that, I had done everything in my power to break them free incluiding a six foot cheater bar on a 3/4 drive socket set with a reducer to no avail. My torque gun only went to 450 ft. lbs. but I put way more force on them than that. I even beat on the pry bar with a 20lb hammer. There is something about that quick hammering effect of a torque gun with high impact values that will spin them off. Try it before you go to the trouble to replace the spindles. They will need a large impact gun.
Huh, i wonder if it allows the bolt to tighten more? my uncle that has been a mechanic for god knows how long has said to always put never seize on any nut/bolt you take out of something. i would have never thought that it would do that.
If you are going to use an Impact Driver with an 1 1/8 socket to remove blade nuts or bolts you should be looking at no less than 600 ft.lbs. of torque. If you're thinking of buying an Impact Driver I'd suggest the Ingersoll Rand.
Ric has the key to this problem. In copying torque charts for the forum (threads, lube, torques-current) I note that a 1-1/8" nut in grade 5 takes 794 ft lbs to tighten. BREAKING TORQUE IS BEYOND THE CAPABILITY OF THE BEST RED NECK BREAKER BAR UNLESS IT IS A 10ft 4x4? This is heavy equipment tool capability? Again...why would a mfg set up such an obstacle to the poor home
gardener?:confused2: rfi also saw this clearly.
ERROR ERROR SORRY SORRY Entered the bolt chart ID instead of the backing into the shaft from the nut size discussed. If the shaft is 7/8 od the grade 5 torque is only 382 ft lb, but breakings torque is ? 420 ft lbs? If that bolt is put on dry it is beyond the capability of most home mechanics tools. So sandburs approach is understandable: neverseize drops required torque 45%, to 210 ft lbs, within the range of my trusty crafsman wrench. And breaking torque down to ?230 ft lbs, still a one man job. Ah, the joy of proper lubricant, Again my apology for the error. :ashamed:
Something is still not right here for me. I don't have access to the nut/bolt on the CC Z force 44 so I'm working off paper. No free online manual but owners and e how all say torque should be 125 ft lbs. This must be for a 5/8" threaded shaft grade 5 (chart is 145 dry). This makes the nut wall really thick to result in a 1-1/8 " socket (big, beefy), and three times more difficult than my craftsman (50 ft lb) to remove. Maybe what is happening is that owners (and dealers) can't properly torque the nuts with a torque wrench and resort to big air hammers??? This could explain the difficulty getting the nut off. Tire shops well known for over torquing wheel nuts and damaging brake discs. So the poor CC gets over torqued on and impossible to get off. Someone please measue the threaded shaft dia and advise.:confused2:
Ok I had the CC 44" and I'm still running the CC 48". Both use the 1 1/8 socket to remove the blades. Torque on those nuts on both are 100 to 120 ft lbs ( that's what the manual calls for ) I would not torque those nuts at over 80 to 90 ft lbs. I never ran over 80 ft lbs on either the 44 or 48" and never had any problems. The spindle shaft size is 3/4"
IGNORE/NO COMMENTI just bought a set of blades for my Cub Cadet Z-Force 44" and have run into problems removing the old blades. The three blades are each bolted on by a 1-1/8 nut. I have attempted to remove them with an impact wrench, socket and pry par, socket - pry bar - sludge hammer combo, torch, solvents, and praying. I cannot get a single nut to rotate and looking at the threads as well as the manual, they are common threaded nuts which left turning "should" loosen. Any suggestions? It's hard to even get a bite to wedge the blades stationery on this thing.
THANKS!
I'm stuck on this one. A 3/4" threaded shaft in Grade 5 takes 257 ft lbs dry, 157 lubed; move down to Grade 3 takes 234 ft lbs dry, 137 lubed; move down to grade 1-2 low carbon steel takes 155 ft lbs dry, 95 lubed. ?????
But this machine is a cut above? The shaft is hollow for greasing? The grade 1-2 is plain unmarked wood working stuff. A thick nut makes a person think air hammer. We should call sherlock holmes.
:smile: What size of impact are you using and how much air pressure? I have removed plenty of blades off cadet decks and various other decks that have not been off in years. I spray them with PB blaster let them soak for awhile and then use my 1/2" inpact at 130 psi. Never had one that did not come off. Try this trick, heat the nut and when glowing red, take a candle and soak the wax in between the nut and the threads. Then put the inpact to it. Don B.
:smile: Ric, I was asking Zkizzot, about the impact. Take the Dremel and cut a slot in the nut, then take a cold chiesel and drive it down the slot. that will open the nut up and then remove the nut.
:smile: Maybe that is a bit extreme. But is is evident, that several people have suggested taking it to a shop, and he's not going for that. Most people only read the manual, when something goes wrong. I have seen some incorrect information in some manuals. The old saying, when all fails read the manual. You are correct about the impact. Especially people that haved used hand tools all the time and never been exposed to impacts. Then all a sudden they get impact tools.
As far as I get from this is he used heat. As for my self if that that would mean new bearings or to the very least repack them with grease unless you have grease fitting? I have found a impact wrench isn't always the answer to remove frozen bolts or nuts. I have found a long breaker bar some times works better. When I was working on big trucks some of the torque setting on the transmission yokes ran over 600 foot lbs. We used what was called a torque multiplier.
If it were me I would use a nut splitter. Crank it down and split the nuts. They'll come right off.The deck is off and upside down. I did only heat the nut whereas the purpose of heating is for expansion and you want the nut to expand off the bolt threads....thus only what the bolt is going through is ever heated when using a torch. Penetrating oil has soaked all day, they are right hand nuts, and I don't want to have to replace the expensive assemblies because old blades are stuck to mine. I would consider replacing the shafts if I could get those off. A cold chisel would have about the same effect as the impact I am using as well as the rotary hammer I put on it. I have a garage full of tools and nothing is working. I just can't believe all three nuts won't turn. I talked to my buddy who owns a lawn service and uses cubs and he had no advice other than what I've tried. I may find a way to strap the deck down and attach an aerial winch to the breaker bar to see if 10,000 pounds of force will do anything (That's what we hoist the alligators up with)
This thread has very heavy viewing. Has anyone figured out if it's corrosion, overtorque or damaged threads (from over torque) which is causing the great difficulty? Early on we decided it should only take 125 ft lbs to properly tighten.
Skizzot. if you think you are going to be long solving the problem, best to go and spray the lawn out with Roundup.:laughing:
THANKS!
...... Really you should consider your self lucky to have the 3/4" shaft with greasable spindles, you will not find those in 90% of the residential mowers made today.
I like the theory of selective heating the nut, but the seal would go quickly in overheat and so would bolt hardness.
This cub cadet nut thing is still a puzzle (read this thread). It would seem that the factory ?125 ft lb? torque callout would avoid these "frozen" bolts. But the very large size of the nut no doubt tricks mechanics into applying huge tightening torque. Remember that never seize only worsens the application of "unadjusted" high torque as it over tightens the nut.
Tell me more about the fake zerk fittings on my Craftsman that I regularly grease. Since 2004 I have pumped in at least 1/2 cartridge worth and never seen any expelled.
djdicetn, Well that do beat all...Even the crafstman manual shows diagrams and instructions that all "jerks" should grease zerks. Only your high credibility allows me to belive this. So the zerks are "little white pills signifying everything, but doing nothing." Craftsman (or MTD) should have saved $ put into the zerks and put on an overtemp gauge so owners don't fry their engines. One flew over the cuckoo nest..... motoman
PS I won't miss tearing up my arm to reach the center zerk. Where's the grease going? :laughing:
