1) just bought it or owned from new ( or 2nd had a long time ago) owned 10 years 2nd owner. Trouble free
2) how may hours ? 250
3) where did you get the belt from & what was the brand / part number ( if you still have the sleeve )Amazon
4) did you remove either of the rear wheels when you replaced the belt ?no
5) if you jack up the rear so the wheels are clear of the ground then start the engine & engage the drive do the wheels turn in the same direction , opposite direction, one moves & the other does not . If the latter, have a close look at the wheel that does not move, is the axel moving ? Rotate same direction but you can make them go backwards but if you touch them they stop. There is a shaft on the bottom right of the gear box that is turning and it goes forward and backward.  I have videos but can’t seem to upload them. Uploading to you tube will send links when they are live. Thanks for your help
