Hi Team,
I have a B&S 500e powered lawn mower. I have only had this thing a couple of years or there abouts, so not very old at all. I went to start it a couple of weeks ago and couldn't get it going. Been sat in the shed a few weeks prior and was working fine. Have noticed a few months back that it was getting harder and harder to start. Anyway, I've had it apart. Have cleaned the carburetor, although it was mint inside. I have checked the oil level. I checked the armature resistance and got a reading of over 6Kohms ( I read that these should be between 2.5 - 5Kohms. Not sure how accurate that is?). So I ordered a replacement which reads at 8.45Kohms, so I am assuming the readings on these are not necessarily reliable to go by? The gap recommended on the manual for the armature is between .006 - .014 in, so I went inbetween at .010. I also replaced the spark plug. Still, I get not start. I get backfires occasionally, but not even a hint that it wants to go. I am a bit stuck at this point.
Thanks in advance!
Thanks in advance!
