Thank you sir for the response. I am beginning to understand how this circuit works. Making sense now. I could not figger out why they put diodes in there in the first place! Hustler did a nice job on those wire looms and I hate cutting into them randomly looking for those diodes. I think I will just re run two new wires from the oil pressure and temperature sender over to the control panel put a couple of diodes in and run from them over to the buzzer. Am I correct that this wire is the ground side of the buzzer? The other side goes over to the diesel controller, not sure why but it does. I took the controller off and cleaned the terminals to it and reinstalled. (first thing I ever do on wiring is clean everything) again, thank you for your assistance, it builds my confidence considerably! One thing I have discovered it that althought I know what a diode is, that is about all I know. Looking as the many diffent types, specs, etc. leads me to ask, what value and kind of diode would you try? thanks!
