johnbell47
- Nov 5, 2025
- 18
temperature warning light does not work. changed temp switch, still no work. Old switch appeard to be new and ohmed out like it was for a gauge, so I think it was the wrong switch. no markings. I changed it to an old timey warning light switch, (Standard TS 66 for a light. had to retap the thermostat housing for NPT threads to make it fit but it does fit and does not leak, bulb is new. I am NOT showing continuity between sender switch connection and other end of the wire at the light. I see in the wiring diagram that there is a diode somewhere before wire goes to alarm. Where is it? thanks for any suggestions. I ran a temporary wire from sender to switch and it does operate but no alarm.
