shaft drivin race mower fx open outlaw modified
7200 rpm but them thare little engine don't last long doing that
You are in the wrong sport if that brothers you. We pull with the full size tractors and have custom rods and pistons made. Now you want a engine to hold up for more then one race and have a longer running time then we do. I don't know how long a race will last? When we do a pull the engine only has to run for a few minuets under full power and we will only do two or three pulls a night. When something go's wrong and a engine blows we can have a pile of junk parts and it happens. We just start over again with newer ideas.
no it don't bother me give me a chance to see what went wrong and why by the end of the second year I had engines lasting half a season , I learned how to do allot of stuff I was changing cam profiles larger valves different flywheels making custom coil brackets im just jumping in with both feet and using a motor no one really uses for performance it is the onan 20.5 vtwin they pull like a bear just not allot if any performance parts for it , it will be a long road of research comparing its internal parts with other manufactures , for example the Honda motors part will fit and run well in clone engines .. the motor has one carb I would like to find or fab up a sheet metal intake for dual carbs or find what other carbs that breath better would fit on the onan intake,, usually on average a race will last 10 min but its usually at wide open ungoverned,, I did run a two stroke 440 snowmobile engine in one race and it was just unbeatable I melted the beads out of the rear tires and was trapped at 68 mph out of a turn in stat line Illinois but I was black flagged due to the oil the exhaust puts out from other drivers I probably could have remedied that but that was the last race I did
well today I replaced my fuel pump and engine runs great, I installed the drive shaft that is going to run my transaxle, and I installed the 1 1/4 axle sprocket and hub with new bearings and bearing hangers, this weekend I will try and have the transaxle bolted in and the chains on I will be using #40 roller chain hopefully next month will be putting all 4 wheels on the ground ill let you know the progress and ill try to get some pictures
# 40 seems like light duty chain, why not # 530 motorcycle chain.
