taylorteamracing
I apologize up front my punctuation it is terrible.,.,.,lol k
I am building a open fx race mower, so far I have the front axle done, it is 43 inches wide with all adjustable caster, camber, and toe, on hiem joints.
the frame is made from 1 x 2 steel tubing and the wheel base is 48", and its 4 inches off of the ground. the motor is a onan 22.5 performer, it is set up with a torque a verter chain driving a 3/4 shaft back to a peerless that's turned up with two u joints to connect to the drive shaft, I have a sprocket on the brake hub of the peerless, that drives the axle sprocket, I am using 13x6.50x8 all the way around ,currently I am working on the open dual exhaust, I am really interested in how it will run I would like to find a 700 trans there a bit stronger I would also like to find some performance parts for the motor but im not having any luck, if you have any tips or question shoot
