Do I need a wheel puller or special tool to remove the hub from the shaft of my stwc Scag mower?
M Michael Cissell Forum Newbie Joined May 21, 2018 Threads 1 Messages 1 May 21, 2018 / scag hub removal #1 Do I need a wheel puller or special tool to remove the hub from the shaft of my stwc Scag mower?
ILENGINE Lawn Royalty Joined May 6, 2010 Threads 51 Messages 11,218 May 22, 2018 / scag hub removal #2 If you have the hydrogear drive units according to hydrogear it requires a special puller and the hub is non reusable.
M Mad Mackie Lawn Addict Joined Jul 11, 2011 Threads 50 Messages 1,851 May 22, 2018 / scag hub removal #3 Assuming that the OP is referring to the hub on the wheel motor, Scag Wildcat has separate pumps and wheel motors and a special wheel puller is needed to remove the hub. The hub is reusable and is also the brake drum for the brake band.
