Do I need a wheel puller or special tool to remove the hub from the shaft of my stwc Scag mower?
M Michael Cissell Forum Newbie Joined May 21, 2018 Threads 1 Messages 1 May 21, 2018 / scag hub removal #1 Do I need a wheel puller or special tool to remove the hub from the shaft of my stwc Scag mower?
I ILENGINE Lawn Royalty Top Poster Of Month Joined May 6, 2010 Threads 39 Messages 10,060 May 22, 2018 / scag hub removal #2 If you have the hydrogear drive units according to hydrogear it requires a special puller and the hub is non reusable.
M Mad Mackie Lawn Addict Joined Jul 11, 2011 Threads 50 Messages 1,851 May 22, 2018 / scag hub removal #3 Assuming that the OP is referring to the hub on the wheel motor, Scag Wildcat has separate pumps and wheel motors and a special wheel puller is needed to remove the hub. The hub is reusable and is also the brake drum for the brake band.
