RZ46i zero turn ignition issue
TrevS
I received a barely used RZ46i zero turn made in 2013 with a smart switch keyless ignition from a family member that the switch panel doesn’t illuminate. I was hoping someone had some experience with these and could tell me a few things to check. Does this switch only need a good battery connected to illuminate or does it need some of the other safety switches in the correct state? It has a new battery but still no power at the ignition switch. Thank you for any help someone can provide.
mechanic mark
see if this manual helps, see page 52 & check 20 amp fuse for replacement.
Check all wiring at back of switch, tight connections everywhere. Also make sure switch is tightly mounted & ground wires are all tight by hand. Check all wire connections for rust & corrosion, wire brush will come in handy. Use silicone dielectric grease on all electrical connections after cleaning them up.
A wire that has broken at the crimp will do exactly what you describe
