firedawgsatx
Ok, can you give me a brief explanation on how to do this? Thanks
There are many approaches to check for and correct a sticky valve. The easiest method to check for a stuck intake valve is to remove the carburetor and shine a flashlight into the intake port. If it's sticky, it will look brownish inside the port and on the valve stem. Carb cleaner sprayed inside the port and on the stem will normally fix it. To check for a sticking exhaust valve remove the muffler and do the same procedure in the exhaust port. Spray inside the port and the exhaust valve stem and spring with carb cleaner. Remove the spark plug and gently turn the flywheel to see if the valves open and close. If you want to get a little more into it you can remove the valve cover (the part in the front with OHC on it) to expose the rocker arms, the valve springs and the ends of the valve stems. While you have the valve cover off you can check and adjust your valve lash as you should be adjusting your valve lash on a regular basis. There was a Honda bulletin I came across once that says to free a stuck valve, remove the rocker arm and seal. Then carefully heat the valve stem with a heat gun until the valve starts to move . Then oil the stem and reassemble. The heating process only takes 5 min. Be CAREFUL if you decide to do this!!!!! Don稚 forget that if you remove your valve cover you will need to use Honda Bond or another sealant on the cover. I use Permatex Ultra Grey and it works very well. There are some good videos on youtube that will help you if you search for adjusting valves on a Honda GCV160.
