how do you remove flywheel on Honda H2113HDA rider mower
robert@honda
  • / how do you remove flywheel on Honda H2113HDA rider mower
To remove and install the flywheel, three special special tools are required.
A strap wrench is necessary to hold the flywheel so the large 16mm nut can be removed.
Once the large nut is off, a flywheel puller (3-bolt) is needed to pull the flywheel off the crankshaft. When installing the flywheel back, use a torque wrench set to 79.5~87.0 lb.ft and the strap wrench to properly tighten the 16mm nut.
motoman
robert, way to go...just what ron needed
ron, looks like the diy tool would need a spacer to clear the fins...
Ron Beard
WOW!! I want to thank everyone for their help. I am going to try to rope trick and if that does not work, see if I can locate where to buy a strap wrench. I have tried other forums before for appliances, cars, etc and had little success. This is an absolutely great site and I truly appreciate everyone's help.
Ron Beard
I want to thank everyone for their help. I could not find a strap wrench, so ended up making one. I thought I would pass on how I made the wrench in hopes it may help someone else. (I also stuck about 3' of nylon rope into the piston chamber, just to be on the safe side).
This is how I made my strap wrench. I took a 42" piece of 1-1/2" inch wide nylon strap (almost too short-48" would be better), looped each end, and stuck the ends through the slot of a 1/2" socket that has a slot cut out of the side to remove temperature sensors on heavy equipment. My socket is 7/8" so enough room for the nylon loops, but I think an auto oxygen sensor socket would also work-it is made the same concerning the slot. Usually you can borrow an oxygen sensor socket from the major auto parts stores at no charge, so it is worth a try. When I stuck the folded ends of the nylon strap through the slots, I stuck a bolt in the fold of the nylon, so the ends would not pull out, but do not know if that really helped. A regular oxygen sensor socket may not have enough room. Anyway, with the strap wrench and rope-in-the-piston-chamber, it broke loose with little effort. Again, I thank everyone for their help.
struckus
Can someone tell me exactly what flywheel puller (3-Bolt) to get to pull this? I keep searching and I am not sure. There seem to be many different pullers.
