Two-Stroke, I'm still working with the digital compass because it did keep the Mule
on a straight heading with the reel mower, yes it did waste a lot of energy trying
to turn the reel mowers with its six fixed wheels spring loaded to the ground but
it did work, the electric rotary deck I'm testing now has two casters to maintain
cut hight which can turn any direction with little effort from the Mule which should
require less energy(from the drive system).
I did test the compass as it was set up for the reel mowers, but the electric motors
on the new test deck interfered with it's reading, last night I did get a chance to move
the compass to a new location and should know today if interference is gone.
some quick calculations seems to suggest that to cut 4"(off the top) of grass in a 4 acre
field using a 38" electric deck would require close to 300Ah of batteries, while cutting 1" (off the top)
would need 120Ah.
I hope to get a chance to replace the mulching blades with standard blades to see if the
energy requirements change.
Tommy
twall, with only four months until this project needs to be completed(self set deadline) I doEverytime I turn around, there's another post in it!
Two-Stroke, It seems the gene pool is not all that fair for some of us, because for me the nuts & boltsIt seems to me that getting the mowing units to work should be relatively straightforward -- no great complexity there.
I was not able to find a good location for the compass where the electric motors of the mowing deckIt's good news if the navigation system is working.
Two-Stroke, the current envisioned navigation system is a collection of senors.It's good news if the navigation system is working.
Yaw senor is just two rotary encoders, one is located at Georges center of turn
and is calibrated in degrees, the other has an 8" wheel that is used as an odometer, the
easiest way to describe it is a Scully.
Digital Compass this is an over the counter, plug&play device that can measure the
earth's magnetic field an allow you to use that information in your computer software.
Gyro this is also a over the counter, plug&play device that is used to stabilize George's
two wheel drive/turns system while pushing snow or mower deck.
Accelerometer this is also a over the counter, plug&play device that is used to stabilize
George while accelerating and decelerating.
GPS this is also a over the counter, plug&play device that allow you to use GPS information
secret weapon the real secret is if it'l work! last few years we'v been able to buy electronic
pet locators, I think they could be used to correct for GPS position errors.
First tests of the Yaw Sensor on sunday products some interesting results, the first test was to
see if the Yaw sensor could keep the Mule tracking straight over the test area with the mower
deck off. and it failed, just because I was there I tested it with the mower running and it did a
sweet job, made it from one end to the other?. seems the tall grass was causing the sensor to
float?, when I tried it with the mower deck off and me pushing down on the sensor it also worked.
Test area pictured below
Tommy
Two-Stroke, its more timing issues(speed of senors) then prioritizing in the current configuration.Since you have so much data to work with from all these sensors, does the decision-making software have to judge the priority given to different (potentially conflicting) pieces of data?
I use the Mule(with Joystick) to cut both of our lawns, so she's alway happy to see George, andWhat does your mom think of this?
IMO George has already helped her, she hasn't had to deal with either so far. granted I didThis is still a project to help her cope with yard work and snow
As is I used simple hand-tools found in most junk drawers to put this stuff together,some video of your testing
Two-Stroke, each sensor has it's function, and limitations. The absolute positionI still can't quite understand how George's controlling software deals with it when input sensors give conflicting information.
The idea weight for george is 500lb for plowing snow with chains, and mowing with these 10 inch wide turf safe tires.I know George is very heavy
George has been on two road trips(back of pickup truck) so far, both last winter to do modificationscan you transport him in a trailer or the bed of a truck?
That is kinda funny, I was thinking the same thing.probably too heavy to lift
