Mad Mackie
- Jul 11, 2011
- 1,851
Is the valve cover on the cylinder in question filling up with oil?
Have you checked to see if the oil return in the cylinder head is clear so the oil can go back to the crankcase?
Also I would make sure that you have the correct dipstick and fill to just below the high level mark, run the engine to warm it up and recheck. You may be overfilling it if you put in the amount of oil that is specified which is a dry engine fill amount.
Are the cooling fins on the cylinders clean?
