Ric
Are the back tires on the 36 really narrow? Because I've borrowed a gravely compact 34 once and it made ruts in some of my yards. Some of my yards are on Lake front properties and is always a little wet and those narrow tires didn't help lol
Well that depends on what you call narrow. There not as big as the Z Master drive tires but neither is the mower. The 36" weighs in at 756 lbs so you really don't need those larger tires like and 11 or 1200 lb mower would use. The Tire size for the 36" is 18 x 8.5 Now if your asking me if it will makes ruts then the answer would be yes but no more so than any other commercial mower is going to make. The key thing with mowing and not making ruts is to change direction of cut every time or every other time you cut the lawn, that will minimize the ruts.
If you've been following the thread you know both the mowers I use are under 1000 lbs that's why I run what I have because like you I have a situation with wet lawns that stay wet. In the Sub-divisions that I mow there's a minimum 10ft between some houses with the low portion of that 10ft in the middle for drainage and it can be horrible to cut and that's where the Turf-Master comes in handy.
If your setting up for your business buy your mowers according to the area your in or mowing, don't listen to recommendations for people up north because the greatest percentage do know your situation here.
