Carscw
If that came to be i would probably just let the air out clean out the slime myself and then take it to the shop.
Why not just take the 10 mins or less and change the tire your self. And save your money.
Sent from my iPhone using LMF
The only thing I used slime in was my motorcycle tires and that was because the shop recommended it. It works great but it is nasty stuff.
Thank god your still alive after doing that.
There are to many bike wrecks every year from people doing that.
It's a fast fix to get you home or to a shop bit at high speeds your just asking for trouble.
I guess your right and the MMA is wrong.
The product called "Slime" is a liquid sealant recommended for Off Road and Slow Speed tires. I would not recommend the use of any sealant or patch as more than a temporary fix. Some shops may even refuse to mount a tire on a wheel so treated. In any event, your tire changer will be angry when they break that tire down and you adorn their tire changer in slippery green slime.
There are probably other, balance related issues related to its use. For example, (not an issue in TX, but..) does it freeze? If so, it will not be able to disperse properly when you ride. This will throw your tire balance off however many ounces of product you injected. A couple ounces is a BIG deal in a motorcycle tire.
Edited by - Niebor on 08/09/2006 6:15 PM
I use it in my car, but never in a bike. If that stuff does not coat evenly you get a non-balanced tire and lots of vibration. Also the goop is not intended for long term use, it is temporary, so you can get to a garage to repair/replace the tire.
I would not want some goop being the only thing between myself and a crash..
Do not use Tire Slime in Motorcycle Tires.
You can:
1. Replace the tire.
2. Plug it with the string type plug.
3. Take off the wheel and take it to a shop to install a plug-patch.
