turbofiat124
How does one go about filling tires with water? I wouldnt use antifreeze if it pops or spills on your lawn itll kill it. But windshield fluid is an idea .
Even pure antifreeze won't kill grass.
Pure water will rust out metal rims in no time. I have one of those little red wagons and after about 5 cans of fix-a-flat per tire, I finally gave up and decided to buy new tires. By that time the inside of the rims were so badly rusted from the the water in the liquid latex the bead section of the rims were badly pitted they required tubes. I grinded away what rusted metal I could and painted the inside and outside of the rims.
About as bad as that calcium crap they used to put in tractor rims. I had to replace the front wheel on my dad's 58 Ford 800 because even the *new* stuff rusted from the inside out. Don't know what the new stuff is.
Still trust my friend's judgement that putting anything to weigh down the rear end will wear out the transmission. I think AG tires are the way to go.
Tractor Supply seems to be the best place to buy tires.
