pugaltitude
You want to check for amps coming from the wire with the diode and voltage with the other wire.
Batteries charge with DC amps.
Think electricity like a river. Volts are the water flowing. Amps is the power pushing the water down river.
Yes you need flow (volts) but you also need the power (amps).
If you do this test it kills 2 birds with one stone.
Does your Multimeter have DC Amp scale?
If so then move red multimeter wire to the 10 amp DC slot.
Disconnect white connector. Insert multimeter red probe to wire with diode.
Attach other probe to battery positive.
Turn dial to DC amp setting on multimeter. Start engine and set rpm to 3600.
You should have amps between 2 - 4 amps DC.
If not then check fuse on multimeter or diode is blown which do diode test.
