buellin745
- Jun 4, 2012
- 3
My smartdrive was barely working so i removed the handle to check the cable and now it wont go back on. When i get it together the pin seems to pop out of the slot in the handle.
The were a number of variations of the SmartDRIVE control. Give me the serial number off the back upper edge of the mower deck (it is in the form of "MZZZ-1234567" and I can share some service details.
Is your mower an HRR (steel deck) or HRX (Nexite/composite "plastic" deck) model?
Doe the SmartDrive control have a slide control to adjust the position like this or not?
The Ser # is MZCG- 7237991 it has a steel deck and the handle assembly is not like the one pictured. Thanks for any help.
Okay, here are the drawings I have for your mower; hope this helps.
FYI, there is an update kit available to convert the SmartDRIVE control to an adjustable version, with five different positions for the grip.
You can order it from any Honda dealer. Refer to Honda Lawn Mower Service Bulletin #75, "Smart Drive Grip Improvement" and the kit itself is part number 04401-VL0-B00 "Clutch Grip Kit" and the MSRP is $21.00. Find a dealer at this link:
Find a Honda Dealer
I've tried couple of times, but when I put together the lower and upper grip, the roller pin goes out of the slot in the grip. what you do to keep the roller pin in to the slot?
