ASEAudie
Cool - so you have rebuilt these motors before I am guessing.
Looking at the exploded parts diagram and the Shop manual it does not look too bad.
Do I need to borrow a Torque Wrench for the rod bolts?
And someone told me muratic acid was the trick to get any alum off the crank.
Thinking about it not likely that alum rods could have done much damage to the steel crank.
Thank you for your help very much.
Muratic acid indeed, followed by some emory cloth to polish up that crank journal.
Torque wrench indeed, follow the specs. in the service manual
Check in here with your progress, and let us know how it turned out.
