C
698281 is correct flywheel used before code 12071800. Options are to find used one. New old stock from somewhere in the World. Replace engine with new for about $1000...such as 33s877-0019-g1. That engine is for a tractor with manual engagement mower deck...9 amp stator. As far as having the 591749 keyway cut to another location...that can be done...BUT, the flywheel must be balanced. A out of norm fix could be to fit the 591759 to your engine without a flywheel key. The crank end should have a slight taper, as should the flywheel. As much as lapping valves with lapping compound, you could lap the flywheel to the crank... basically you are ever so slightly roughing the surface for more of a friction fit to work with the tight taper fit. Use the original flywheel for alignment. The keyway on the 591759 won't be close to the crank keyway. Remember you are eliminating the key. Try it dry, it will start if you get it aligned exactly. Once you have it to that point, mark it's position with the crank, remove and use Loctite stud & bearing mount to "glue" the flywheel and crank together. This is a high strength adhesive that will require a puller & 500 degrees of heat to disassemble. Install nut and torque to 110 foot pounds. Another option would be to skip the Loctite and just torque the nut...it might stay in position forever or need to be redone in the future. Good luck !
