This is a Husqvarna YTH18542 riding mower. B&S 18.5 hp engine. 42" cut. Original owner. Bought new 8 or so years ago.
Brought it out of storage this morning to do a mow, then changed the oil and other maintenance. While changing the oil, I smelled gas and could see gas dripping from the top of the carborator, down and all over the bowl. No drip from the supply lines. Definetly coming from the top of the carb. Tried to turn over the motor and it was stuck. Tried turning the flywheel by hand and could gear a gurgling noise coming from the air filter inlet. Shut off the gas supply and removed the top cover and the spark plug and fuel began leaking from the cylinder. Turned it over by hand and could see more fuel gushing out of the spark plug hole. Using the key, I turned it over a few revolutions to clear the cylinder. With the gas line still shut off, I replaced the spark plug and turned on the fuel again. It started reluctantly but once it started it ran normally. Shut it off and waited awhile to see if the leak reappeared and it did not. So thinking it was just a sticky needle or something, I reassembled everything and went to start it again and again it was stuck. Tried moving the fly wheel by hand and again could hear fuel gurgling in the cylinder. So cleared it out again, this time leaving the fuel shut off until I was ready to start it so I could move it so my wife could get her car out of the garage. So I moved it back to its storage place and am now trying to figure out my next step.
I was at first tempted to use the battery jumper on it, thinking the battery was a little flat for some reason (keep it on a tender over the winter) but probably a good think I didn't since the cylinder was full of fuel and I could've hydro-locked the engine and cracked the block.
I store the mower with an empty bowl, shutting off the fuel and letting the engine die. I always put in some gas treatment before running it dry. I bought it new and it's never had a whiff of ethanol fuel in it.
I know nothing about carbs so please, talk to me like I'm an idiot. Is there anything I can do to loosen up the sticky "whatever" without having to remove the carb all together? I'm deathly afraid of getting this thing taken apart and not being able to reassemble and make it run again. I posted a pic of the valve cover numbers so you can see what engine it has. Sorry it's sooo big. I might be willing to try putting in a rebuild kit if someone might know what kit it needs. I have the B&S parts manual and it lists a few different kits for different carbs. I'm guessing I would need to order this from B&S directly.
It's funny because I've rebuilt hydrostatic units on these mowers before and had no reluctance to tear into one but you give me a carb and I'm like a blithering idiot.
Thanks for any help.
