I have tried three count em three, different carbs off amaz and flea bay,
Could of bought the wrong carb or the cheapest listing. I've had better luck buying a carb at say 10-15 bucks more than the cheapest listing. Can't explain it.
it has the electric shut off and not one will keep the engine running for a constant operation
With the key ON, do you have 12 volts DC AT the after-fire solenoid wires?
I then went to a sears pts catalog found that the Nikki carb is specific to this model and just ordered another one yesterday.
Oh boy, the dreaded Nikki Six carb strikes again. Some guys have luck with them. Me, I do the Walbro swap and never look back.
I found the coil s/o wire grounding out fixed that then adjusted the valve lash thinking burnt walves or bad seats, got it to run 3/4 throttle then is started dieing out then stalled, started and wouldn't barely run.
I'm going with trash in the fuel tank or lack of fuel delivery to the carb. An 11 year old mower, that tank is probably full of trash getting passed straight to the carb. Not to mention your fuel can. Do you have an OPEN TOP spout or a new style EPA pain in the rump spout? The type that takes 10 minutes to dispense a single gallon of fuel?
Red, you are throwing a ton of parts at this. Every NEW part you buy, REQUIRES TESTING. New doesn't mean new these days. Coils, carbs and so on......... I feel your frustration.
This tractor was a gift with numerous issues, it is a flood survivor,
What is not corroded far as electrical and such? You are going to have to go through everything on this mower to get her running proper.
This last carb as gov. kept moving back and forth, so I just accepted it and ran it,
She is running lean. She is thirsty, wants more fuel. When she does this, apply the choke to see if she smoothes out. The hunting should stop if she is lean. Check for vacuum leaks too.
yesterday, it started again with the popping, blk smoke, stalling and barley running, way over rich, wouldn't clear up for nothing sooo I ordered another carb
NOW, on THIS carb, we are rich as in the needle and seat probably are not sealing. Again, any and all new carbs will require testing. Pressure test the needle and seat at 7PSI for 30 minutes. If she holds, the needle is good. Spray something like PB Blaster on the needle tip when you do this test. Needle needs to be wet just like in service.
I know it is an older mower, to be honest these are not that complicated but this type of carb to me is, especially the warning "Must be specific to this engine" so help!!
Carb is well known POS. Most "non" sought after carb out there. Some guys have good luck, not me. Walbro swap again will do you wonders.
When I get a new to me used mower, if I see the word Nikki on the carb, I don't even mess with it. Order a 594593 Walbro.
