listen, I want to thank all of you for the replys. I will get the number today I am up ay 4am most days have to wait for the sun a little bit this morn. Until I get out there, a little history, this mower was a gift for a rewire on a neighbors garage, he mislead me big time swore he had just cut his lots with it. Ummm no it was a Hurricane Ian flood mower, how to tell? Bottom of hood with water residue, flywheel rusted badly oxidized coil feet so bad I had to literally sand paper flywheel use an older set of feeler gauges just to clean coil gap, got her running. Ran ok except for, both spindles so bad your teeth would run away when blades engaged oh the blades? hahahahahah ok sure, well daughter my convinced me to "Why not fix it for back up dad?" ( i am not supposed to be on a tractor of any size anymore by dr orders due to declining health) Soo my dear readers it gets better, I mean since it was running and it was flooded and the seat was broken and 4 tires flat why not, Tires?? well it took a few tries but got them to hold air, then new spindles new blades, oil change of course, check PCV, check Vapor tube from gas tank, fresh fuel, fresh filters air and gas, it was perfect for hauling my cutesy little harbor freight, little red trailer I got, I mean we are talking, "Captain Kangaroo" stuff right here, I thought hmmm, kid went back to college, wifes off at work, I do have a wild overgrown lot with high grass I wonder.........well this pony didn't let me down UNTILL, ( got that until off a YT video, cool huh?) UNTILL- I got stuck, Now my dear Small engine, engineers, is where it becomes 1 against the mighty engineers of a Lawn Tractor Co. who should have all their pencils removed, On the 7 speed tranny it utilizes a shifter that travels between F-N-R, which in turn by a cable goes to a round 1/4" rod, ohhhh about 7" long connected to the transmission shift arm, and did you know ( I found out by having to Push home that 42, after getting it out of high grass) if that rod is even looking bent, if it is out of Flat with a machine shops granite inspection table, that damn mower will not shift??? Now I know this may sound "Been there done that" ok that's you, me? living somewhat rural, we don't call magic "Mr, Fit it all when our screen door gets stuck" feel me ?? I wait, use cuss words not invented yet, get the time, pull the shift rod out, anvil time and a square head body hammer, (tin hammer,we call it) and wa la I am smokin" UNTILL another HA another set back. my little trailer from HF just sitting, BUT I did knock the living bahjesus out of that tall grass so my lawnman can get 1/2 of that lot with our lots cut when he comes. He was so happy to see it finally done, after couple months of in house resting went to use the TB that is when it all started, coughing, the missing, the stalling barely hardly any low idle, I remembered my donor said he did carb replacement, so OEM is gone, but in looking the air screw was siliconed shut, I kid you not, umm ok, I order one up from amzcrap, like the story goes hahahahahahaha you just fell into Alice's Wonderland and here we are. I will get and post the Engine number today, I hope I got a laugh from most of you reading this, as it is a totally true story, I have been told no more equipment use due to my declining health, but damn "sir" my mind says different, and until I really can't,my upbringing says something else. anyway have a great day and thanks again!!! Red
