intek 12.5 hp engine cylinder head gasket need to confirm part #
hlw49
Bottom valve is intake top is exhaust. Clearance is .003 to .005 on intake and .005 to .007 exhaust.
so w/ top valve spring compressed I can adjust bottom an it doesn't matter what stroke piston is on ? thanks HLW49
Watch the Taryl video that was posted on page 1. All your answers are there.
hlw49
Watch the video. Engine has to be on top dead center on the compression stroke to adjust the valves.
hlw49 I'm done w/ TDC wasted about 4 hours.
I managed to adjust the valves lower valve set to .004 top valve .006
she did crank up. I then mowed the back yard 1/2 acre. turned her off to gain access to front yard she didn't want to crank up but I continued to turn her over then she did start.
I didn't like to force her to crank up.
maybe the valves expanded when hot could setting both valves at .005 resolve the expanding metal where she will crank up normally hot or cold?
additionaly do you Guys ever run seafoam though the fuel?
thanks
hlw49
yes sea foam is some good stuff
