- May 6, 2010
- Threads
- 49
- 11,175
The problem is not using a rust prohibitor, the problem is the engine is not supposed to set on the shelf for 2 years before being used. I have OEM's that if the code date is 2 or more years before purchase date, you better be able to come up with a receipt.Apparently they need to fog their engines w/ a corrosion prohibitor at the end of the run.
