jmurray01
, , 1,000 Post Club
- Apr 7, 2011
- Threads
- 129
- 1,490
I've seen ducks speak with more sincerity :laughing:Goodbye JD.
Happy Trails.
Happy Trails.
Goodbye JD.
Happy Trails.
I knew it.
JDgreen said:Better to be the bugger than the buggee....
If you are using the term "bugger" in it's real meaning, then I congratulate you in "coming out of the closet". Though I myself am not of that persuasion, I am thankful that someone like you can be a part of this overwhelmingly masculine forum.
It brings a breathe of fresh air when you can share your personnel feelings with us!
Thank you.
Don't worry, I will!
By the way, I can't believe you contemplated leaving LMF! The King can't leave his post! :laughing:
You didn't use the term "bug", if you read your post. You used the term "bugger", which you can look up and see what you really meant.
Perhaps it was just a Freudian slip?
Anyway, congratulations, you are an asset to this forum!
Good for you.
Oh JD... What a hole you've dug yourself into :laughing:You didn't use the term "bug", if you read your post. You used the term "bugger", which you can look up and see what you really meant.
Good for you.
