svlawnmower
- May 26, 2018
- 35
Problem:
My tiller has a 7hp Briggs and Stratton engine (see details below) and I'm having problems with it not starting. I did have stablizer in it previously since it sits over over the winter.
What I have tried:
Engine Info:
121412 - 0158 - E1
Family YBSXS.2051HF - 274479
0008281 D (s/n ??)
Briggs and Stratton 7HP
What I have tried:
- Though I had stabilizer in it, I did drain and replace the fuel
- I noticed the plug wasn't sparking - or it was hard to see it spark. After checking the coil with a multimeter it read t 2.6 ohms. I replaced it with a spare coil I had which tested 19+ ohms and replaced the spark plug with a new one. Used a business card to gap the coil and magneto/.
- I decided the carburetor probably needed cleaning and rebuild and bought a rebuild kit specific to this engine from Briggs and Stratton for this model
- I cleaned the carburetor multiple times intentionally with Carb cleaner and air hose making sure fluid shot through all the holes in both directions when possible.
- Replaced parts and the gaskets - they were in bad shape. This included the bottom bowl screw gasket and the bowl o-ring
Engine Info:
121412 - 0158 - E1
0008281 D (s/n ??)
