The whole point of the thread was to make it into a training exercise. It was to get fellow techs to learn to think outside the box; otherwords, don't get so focus that you miss the real problem. We must be able to troubleshoot without just throwing parts and hope we hit on the solution by guessing.
This guessing just what many shops in my area are doing ending up costing the customer more as they charge for unnecessary parts. And forget if they need to troubleshoot an electrical problem.
The mower in this thread was sold by a local repair shop. It was in a mess from the get go. My customer did make the mistake of buying the mower and should have return it when the very first lie was told about it. He was told it had a Kohler engine and it had a Briggs when I raised the hood. It was acting up so bad I had the customer return it for the other shop to straight it out. The shop put on this junk clone carburetor and replaced the deck. Neither of which solved the problems I had the customer return the mower for.
That just the tip of the iceberg. After I got the engine problem resolve, the mower had three flat tires, dry rotted. Mower deck shakes badly. Bent blades, bad idler pulley, both spindle pulleys are bent, and the blade brakes are working. When you have brought a used rider for $800 and then having to spend another $300 on it just to get it to an usable state is not fun or right.
Anyway I get the mower out this coming week after the deck parts get here. Didn't have the blade brakes in stock.
