- Sep 24, 2017
- Threads
- 280
- 6,778
Have you tried spinning the flywheel by hand? check to see if the blade moves too,.
Have you tried pulling it with the spark plug out?I just had one more thing to say and i dont think this should matter but this all happened right after i did my oil change. I bought some full synthetic 10w30 engine oil it was penzoil ultra synthetic and i tipped the mower onto its side and did a usual oil change and let it drain for 5 min then i put the new oil into it. After it was filled up to the proper line i went to pull the starter cord and thats when this entire thing went south and the mower wouldnt start and people say my crank shaft is broken. This couldnt have anything to do with anything right? Just a coincidence right?
Yes i did try and the new recoiler i put on still wont move with the plug out. I tried spraying penetrating oil into the plug hole thinking my engine froze and let that sit for a few hours but thats not the case it has to be the flywheel/clutch ratchet.Have you tried pulling it with the spark plug out?
ya its very strange but if i were to guess i say a tiny fracture finally let go over time, maybe at some point you hit something to fracture it but it never completely separated until now. i just bought a twin cylinder the guy said he was cutting grass with it last week when it stopped like the key was turned off and would never restart for him. he had a mechanic friend look at it and was told neither cylinder has compression. i find that near impossible both cylinders fail completely at the same time in the middle of cutting grass but i suspect its a valve train failure more then bad engine for the one i just bought.My friend said since there is no compression when i put my finger over the spark plug hole and spin the blade that yes my crank shaft is broken. I dont get it i used the mower the other day to cut my entire lawn. Then yesterday all i did was change the oil then i went to start it up and pulled it 1 time and this happened HOW? How can a crank shaft break by me trying to pull it one time? I'm amazed are crank shafts that easily broken or can crank shafts deteriorate after 21 years?
