Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,914
do you get any voltage change at the wire when you turn the key to start?
If so you have a high resistance connection somewhere. Probably switch contacts.
If no voltage at the trigger wire then try to find a point you can test at somewhere near the middle of the circuit and test for voltage when you turn the key. This will let you half split the circuit and with one test isolate problem to half the circuit.
If you get no voltage then priblem between keyswitch and the test point. If you get voltage then problem between that point and solenoid.
Wire don't fail in the middle without something physically damaging them. Problem is always at the ends of wires or what they are hooked to.
