synthetic oil
Use Ams oil in everything but my push mowers and them I use SAE 30. No oil problims yet. You will find the person that doesn't check or change their oil will have all the problims.
I use Wal-Mart brand Super Tech 10w-30 Full Synthetic oil in both my mowers, and I have never had problems.
Super Tech is made by Warren Industries and it has a little weaker add pack than some but if you change at reasonable intervals you will be fine.
It is much better for your engine than using a conventional 30 weight oil.
I use Rotella T Synthetic T6 I started running it in my Kubota and what sold me is how clean it is when you change it. Less thermal breakdown for sure and in a air cooled engine it has to help...
But the oil should not appear "clean" at the OC(oil change)...
BTW, I use synthetics in most of my engines/motors...
Overkill?
Perhaps....we may never know.
No truer words....and I am playing Russian Roulette...its OC time !
Also note the correct weight. Men do mess up in this area.
