synthetic oil
Annual oil changes??
I change all my engine oils once a year... On my cars, truck, tractors and mowers.
Using a good synthetic I have all the additives to last a year or more but to make it easy they all get changed once a year. :smile:KennyV
Ugh! I used Mobil 1 in all my mowers and I change every 25 hours, oil and filters. I changed to Mobil 5000 10w30 but I still change every 25Hours.:smile:
I have always used synthetic in air cooled engines... they need all the help they can get.
And I switched from Mobil1 last year to Rotella T Synthetic T6... Great stuff and I use it in all my engines With annual oil changes. ... KennyV
I checked out our local supply of Shell Rotella T6 and all I can find is 10w 40. The Kohler book is kinda specific on using a 30 weight oil. In your opinion will the 40 weight Rotella make a difference?
I have one Kohler engine and friends with several... we all run Rotella T6, and have for some time... It is in all my diesel engines and my gasoline cars... yes in my opinion Rotella T6 will make a difference a positive difference... :smile:KennyV
Rotella T6 is 5w-40 not 10w-40...
i use full synthetic sae-30 on my biggs and stratton engine (recomended) and that works a treat far smoother running than i got from non synthetic this needs to be changed once a year:smile:
I've had great luck using Amsoil synthetic in all of my 4 stroke lawn care rolling stock, specifically their product code ASE, which stands for Amsoil Small Engine. Once a year oil changes work for me as well, typically at the end of the season. If I run a mower for an hour a week, it is still less than 53 hours of run time annually. That's still conservative in my book. I do check the oil level before every use, that's cheap insurance.:biggrin:
Thanx Kenny, I will follow your lead. I'll head to Wally World and buy the 5 quart jug.
...I'll head to Wally World and buy the 5 quart jug.
That is the place to get it ... BUT it's a 4 quart... not 5 Quart. Bright blue jug, cant miss it... You will like this oil... :smile:KennyV
Rotella is not good before retiring I was in the trucking business and I used it in my fleet.
I could only get a little over a million miles out of an engine before rebuilding it. :laughing:
