joe gremlin
- Mar 22, 2011
- 5
If you've got 3+ acres of bumpy and hilly terrain to mow, you shouldn't be looking at a mower, you should be looking at a tractor or a SCUT IMHO. For a property that size, you're going to have trouble getting any mower from any manufaturer to hold up in the long run. Yes its a much bigger investment. Better to spend $15k on something will last 20 years or more than $5k on something that will only last 5 years at best IMHO.I really need to by a new mower but I can't committ myself to buying a mower. Does anyone have any suggestions? Any help would be appreciated. I am looking at the JD 320, JD 500, Husqvarna and cub cadet. The John Deere are at a local dealer and run $4000 to $5000 respectively. The Husqvarna is $3000. Help!
Deere, Cub, Kabota and New Holland all produce diesel sub compact tractors that that will handle that job quite well and should last 20 years doing it if you take care of them properly. And they give you the option of easily adding things like a loader (once you have one, you won't know how you lived without it) or numerous 3pt impliments. Trying to do it with a mower, even a name brand $5k unit, is just asking for headaches IMO.
