What's your favorite Weed-Eater Line?
Sprinkler Buddy
My favorite line is Gator Line .095 dia. Holds up well even when edging with your weed-eater. Doesn't tend to melt to itself like many other lines I have used in the past. It has a wire infussed within the line itself. Tough Stuff!
Really - a WIRE? Is that the hex stuff? I think I saw it at HD.....
It's a twisted hex with wire. The square hex tends to not feed well and melts alot. Their has been a few knock offs, not nearly as good as the Gator Line Brand.
Does all the gator line have wire in it?
All that I have seen does. You can physically see the wire inside it. Give it a try, you'll like it. They retail it in very small amounts or the large spool for commercial guys.
4 side square cut 1.05 "Weed Buster", only thing is...it's bright orange:laughing: My wife picks up pieces of days after cutting!:biggrin:
Actually Gatorline doesn't have any wire in it to my knowledge. The line is made of two different materials to give it optimum performance. The core is made from a high strength polymer that resists breaking. The outer layer is made from a abrasion resistant polymer with anti-welding properties. The outer layer is also reinforced with Aramid fibers. I buy the .105 by the spool.
I learned something new, good stuff! I used to use the .105, since this line is so tough I switched to the
.095 to get more on the heads. Less restringing.
Anyone use the individual replacement lines rather than spools?
