Kenny, I apologize for the sarcasm.  After seeing the thread had 70 plus views I figured no one was willing to help.  Anyway, the plug is wet when I pull it after it stalls so it is getting fuel.  I kinda think the coil might be crapping out, but don t they usually just stop working all together? IDK  Thanks Rich
If you'll look at the bottom of the homepage, you'll notice there is a very small percentage of members to visitors.  Visitors can't post, even if they wanna help with your problem.  However, I do believe their view is still counted on the counter for 'views'......
If you'll also notice, not all of us have ALL our interests in JD.....:biggrin:
As to your question, I have seen coils go weak before toally failing.  Just curious - does your Kohler have a capacitor on it?  That sounds like the old JD 110's when they would kinda puke, but not totally....
If it does, try changing it...they're cheap.
And BTW....this IS the best forum out there for this kinda stuff......to echo Kenny.
