GAVolunteer
Honda HRR216-K5-VKA SN MZCG 7812708
Does anyone know the proper procedure to assemble the Smart Drive Control?
I'm working on a a friend's father's mower. I do not know if anyone has worked on it before me.
Problem: The self-propelled the Smart Drive will not engage the transmission when pushed down.
What I've done so far.
1. I took all of the panels underneath the mower so I could access the transmission and clutch cable.
2. I removed the "bottom" of the transmission and drained the oil. In looking at the gears and clutch plate, everything appears to be ok.
3. When I manually push the transmission Arm Control that the clutch cable is attached to, the clutch plate in the transmission engages correctly.
4. I tried adjusting the nut on the clutch cable. It did not help.
5. I then took apart the Smart Drive (attached to the handle). I found that part of the white upper bracket cover was broken (where the select lever meets the bracket cover). See attached picture.
Old Upper Bracket Cover
6. I ordered a new upper and lower bracket cover. I also ordered a new clutch cable, thinking that the old one might have "stretched".
7. I installed the new clutch cable. I also assembled the Smart Drive. I placed the "pin" in the "hole" of the connector of the clutch cable. I snapped together the upper and lower parts of the clutch cable, trying to make sure the pin fit properly in the slots in the upper connector and the slot in the lower connector.
8. Nothing happens. When I rotate the the smart drive control, the cable does not activate the control arm of the transmission. It appears the pin is not moving the cable.
9. I took apart the smart drive again. I took a screw driver, inserted it in the hole of the clutch cable connector and manually pushed the clutch cable to the right. The clutch cable moves the control arm and the clutch plate in the transmission completely engages. So the cable is good.
So, I'm pretty sure that the problem is either in how I am assembling the smart drive or there might be a missing piece (I've checked the parts diagram and all the parts appear to be there.)
Does anyone know the proper procedure or "tricks" on assembling the smart drive so that the pin engages the clutch cable? I'm at a loss.
Thanks.
Clutch Cable and Pin
Assembled Upper Cover
Bottom Smart Drive Contol Cover and Selector
Transmission Not Engaged
Transmission Manually Engaged
Thanks.
