mystreba
Ok, finally had a chance to test it out. It is fantastic! If you have this feature, you should definitely use it. Jetblast had it right - its a great deal for just six minutes of time.
Since I hadn't been using it, I found that I had to remove the deck (mower only has 4 hours!) and scrape all the grass scabs off. After that, I mowed the lawn and used the deck wash. Clean as a whistle.
Make sure you lower the deck to the lowest setting (if on concrete or other hard surface) to get the best pressure and circulation.
