The owners manual shows two types of grease, one is a general lube, the other is specifically for the deck spindles. You can use the deck spindle grease on all lube points, but the general lube is not recommended for use in the deck spindles.
Look around the spindles close to the deck top and you will find the grease fittings. Opposite the grease fittings, there is a pressure vent. The vent is there to prevent pressurizing the spindles while pumping grease into them. I have a 90 degree grease adapter that makes lubing the spindles easier.
There are grease fittings on the front wheels. The front caster swivels may have plugs where grease fittings may be installed. I'm not sure why Scag just didn't install grease fittings in the casters swivels.
There are four grease fittings, one on each of the deck lift arms, the arms have the deck suspension chains bolted to them.
The parking brake lever has one grease fitting.
Each control lever has a grease fitting at the pivot where they swing in and out.
Lift the seat up and look straight down to the rear edge of the deck and you will see a triangular support bracket on each side of the deck, they each have a grease fitting. This is an area the usually is missed, however fairly important.
Look behind each rear wheel and you will see a grease fitting on each of the parking brake actuators.
To make it easier to lube my machine, I have turned the deck support bracket grease fittings so they are facing straight up and I have installed angled grease fittings on the parking brake actuators.
I have photos of some of these lube areas on my computer and I can post them here. If you would like, I can take photos of all the lube areas to make the job easier for you when you do scheduled services on your machine.
I schedule the maintenance on my Tiger Cub to 50/100 hour. I use blank shipping labels and mark the hours for the servicing and I cross them off as the services are done. I put these shipping labels under the seat support. I do engine oil changes at 50 hours and engine oil filter changes at 100 hours. Engine air filters are done when needed.
My machine has a collection system installed and the blower fan bearings get greased with the spindle grease every 10 hours.
Have fun!!!
Mad Mackie in CT :laughing::biggrin::smile:
