Well, I took it out for a "spin" yesterday...it was dry and I had nothing else to do.  I'll probably be mowing the yard at the end of the week if its dry...just spread 100#s of grass seed in an attempt to grow grass in my former hay field.
I had found the drive tires over-inflated after the last outing...dropping them to the recommended 6psi made an absolute world of difference.  No more spinning at every turn, and it rides like its on an airbag.
I basically wanted to see how it would handle the terrain, more than how it would mow.  I took it on the steepest portions to see A) if it would climb them, B) if it would rear up descending them, and C) if it would be stable on the side hills.  I must say I am very pleased, it climbed without hesitation where the old rider would spin sometimes.  It would lift the rear wheel on a steep descent and purposely braking hard, but it was minor and controllable.  It felt very stable on side slopes.  The only thing I will be doing it changing out the "fixed" deck mount bushings for the optional "floating" deck mount bushings...I think it would place less strain on things and mow better if the deck could pivot a little.
I also mowed a small patch, and it does very well...the grass was pretty thick and it didn't even change tune.  It definitely does better with the new blades.
I did check the oil afterwards, and it appears to have flushed some of the old oil out...turned it a little darker brown from the initial olive green.  Probably run it one time, then change the oil and filter as a precaution...I'm running Schaeffers 5w40 synthetic, so it should scrub the insides out pretty good being a PAO base.  Even though I ran it about 20 minutes, the oil itself barely got warm...so the oil cooler must be doing its job now that its got air flow.
