Mad Mackie
- Jul 11, 2011
- 1,851
I also do a fair amount of carpentry work in the winter in a cool garage/shop and this is the reason that I went with the 8511 with the exhaust valve and it just happened to work out for me while operating a dusty ZTR as mine has a collection system which makes more dust. I wear the same goggles sometimes while doing woodworking, like you said, sawing and sanding can produce dust that is way more nasty than mowing. Tablesaws have a tendency to throw particles directly at ones face.
The 8511 has a metal insert in the nose area so adjustments can be made to seal the nose area so air doesn't leak toward ones eye glasses. They are $5.00 each if purchased locally, I buy them in a 10 count box on line for 25-30 dollars and I am about to reorder as I am down to only a few. One of my pics is the front of the 10 count box.
