Murry Furry
No way, if it was up to twenty I wouldn't change. It would just mean that I'ld be robbing banks.:confused2:
Well, here in Ontario we're getting hit by a double whammy. Not only is the price of gas skyrocketing, but most of the effective lawn chemicals are now banned. Unless you own a golf course, (which are exempt), your yard is guaranteed to turn into a jungle. :frown:
I don't think I will if it get to that point. I like to see a well groomed lawn, and I like to smell the fresh cut grass when I'm finish. Besides my Wife like to cut the grass anyways. All I have to do is keep the mower up with the maintenance and make sure it is full of fuel for her. I think it is cheaper then getting sheep to cut the grass anyways.:laughing:
JD Green,
The coyotes around here kill the sheep. I live 4 blocks from city hall. When I built the house I drove 32 miles one way to work, that was 40 years ago. No one has sheep around here. The coyotes climb 7' fences to get to them. They cut into the sheep's belly and only eat the tasty stuff. Then kill another one. I live in Gilbert, Arizona. There's houses for 25 miles in all directions.
Got a JD 48" for the field and Black & Decker 48v electric for around the empty pool. Some times the B&D can mow the back yard twise. Desert front yard with turn drive.
Check out home projects in link below.
http://www.enichesoftware.com
Vern
